[GRASS-dev] [GRASS GIS] #1866: broken db driver communication in winGRASS 7
trac at osgeo.org
Thu Jul 11 10:06:28 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Database | Version: unspecified
Keywords: sqlite, wingrass | Platform: MSWindows 2K
Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:34 hamish]:
> Replying to [comment:33 neteler]:
> > I have tried with r56943 on Windows8, still failing:
> > GRASS 7.0.svn> db.describe overpasses
> is the overpass vector map in the current mapset? You may be seeing the
effect of the db.* modules only working for databases linked from maps in
the current mapset, unless you explicitly set database= to the real path,
not the default which may expand $MAPSET to the current mapset, not the
other mapset's dir name.
In fact it was in a different mapset (PERMANENT). But it should not hang
(instead it should report that the table was not found in the current
mapset).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1866#comment:38>
