[GRASS-dev] [GRASS GIS] #2016: v.surf.idw: very incorrect results
GRASS GIS trac at osgeo.org
Sat Jul 13 23:42:43 PDT 2013
 Reporter:  hamish      |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  6.4.4
Component:  Vector      |     Version:  svn-develbranch6
 Keywords:  v.surf.idw  |    Platform:  Linux
      Cpu:  x86-64      |
Comment(by hamish):
 some more screenshots showing results of r.plane* + v.random + v.surf.idw,
 including some derivative maps from r.slope.aspect (devbr6). The 1000
 vector sampling points created by v.random are shown as black dots.
 [*] trend-plane created by the r.cog addon for spearfish's elevation.dem
 this example is not completely wrong (as is the case in the earlier
 attached screenshot!), just a net of overlain noise on top. So there could
 be two bugs here.
  - http://bambi.otago.ac.nz/hamish/grass/bugs/v.surf.idw/vsurfidw.png
 http://bambi.otago.ac.nz/hamish/grass/bugs/v.surf.idw/vsurfidw.slope.png
 http://bambi.otago.ac.nz/hamish/grass/bugs/v.surf.idw/vsurfidw.pcurv.png
 http://bambi.otago.ac.nz/hamish/grass/bugs/v.surf.idw/vsurfidw.tcurv.png
 note the strands of noise in the NW corner in the curvature maps, and the
 clump of it the center-right of the lower edge in the slope map. Try to
 match them with the r.surf.idw slope map below.
 for comparison, same-data slope map from v.surf.rst and r.surf.idw
 modules.
 http://bambi.otago.ac.nz/hamish/grass/bugs/v.surf.idw/vsurfrst.slope.png
 http://bambi.otago.ac.nz/hamish/grass/bugs/v.surf.idw/rsurfidw.slope.png
 r.surf.idw2 was very similar, but not identical, to r.surf.idw; so not
 shown.
 As expected, v.surf.rst is much smoother throughout although it suffers
 from edge-effects and stitching of the quadtree segmentation around the
 edges. This suggests the quadtree vector map should be created and the
 outer row of segments from it discarded.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2016#comment:2>
