[GRASS-dev] Direct link from GRASS to R via C
Vaclav Petras
wenzeslaus at gmail.com
Tue Jul 16 00:35:57 PDT 2013
you probably know, I've once started the discussion on this topic on
grass-stats ML (very simple test code included) [1]. And I've also
tried some basic example and experienced some problems [2]. To the
information you provided I would add that the new functionality have
to be written in C++ since Rcpp is only for C++.
Vaclav
[1] http://lists.osgeo.org/pipermail/grass-stats/2012-July/001422.html
[2] http://lists.r-forge.r-project.org/pipermail/rcpp-devel/2012-July/004055.html
On 15 July 2013 17:30, Rainer M Krug <Rainer at krugs.de> wrote:
> The following message is a courtesy copy of an article
> that has been posted to gmane.comp.gis.grass.devel as well.
> Hi
> I posted on my blog an outline of an idea of how spatial data could be
> easily loaded from GRASS into R and written back.
> (see http://rmkrug.wordpress.com/2013/07/15/grassrlink-1/)
> In a nutshell, the idea would be to use the C functions in GRASS to
> write a function which returns a single column, column range or whole
> raster. This function could then be called from R (via Rcpp) to get the
> data into R without having to worry about intermittent exports and
> imports via the hdd.
> I would ike to have some input from the GRASS developer community what
> they think about such a function. This function should be usable as
> "stand alone", and not requiring the opening and buffer allocations et
> al as in the r.example, but rather simply take the mapset, raster name,
> column(s) to read, if MASK should be respected, ... arguments.
> I was thinking that it would be useful to have such a function in GRASS,
> as the compilation together with GRASS, in the same line as a module,
> would be quite easy.
> Initially, I was thinking about read and write support for rasters,
> which then could be extended to vectors and 3d-rasters and possibly even
> the temporal data.
> Could you give feedback on what y9ou think about the idea, and how you
> think it could be realized (simplicity to install would be important).
> Cheers and thanks,
> Rainer
> Rainer M. Krug
> email: RMKrug<at>gmail<dot>com
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
