[GRASS-dev] standardized options
Markus Metz
markus.metz.giswork at gmail.com
Tue Jul 16 03:31:37 PDT 2013
You could try G_OPT_M_DIR. The comment says "directory input" but it
should also work for output, all it should return is the path to a
folder.
Markus M
On Mon, Jul 15, 2013 at 5:42 PM, Margherita Di Leo
<dileomargherita at gmail.com> wrote:
> Dear Devs,
> in r57084 Martin has added standardized options to r.ipso (thanks!). I would
> like to learn more about their use, particularly, does it exist a standard
> variable defined for taking a path as input? (Not a path+file name as
> G_OPT_F_INPUT). For example this is useful in the case that a module
> produces some pictures and/or csv files and the user wants to set a folder
> for storing them. I digged into [1] but I seem not to find what I need.
> Should I just take the path as a string? Giving to the user the possibility
> to browse the folders instead of indicating a path would be IMHO more
> convenient. Could anyone point me out where to read in order to learn more
> about that?
> Thanks!
> madi
> [1] http://grass.osgeo.org/programming7/gis_8h_source.html
> Best regards,
> Dr. Margherita DI LEO
> Scientific / technical project officer
> European Commission - DG JRC
> Institute for Environment and Sustainability (IES)
> Via Fermi, 2749
> I-21027 Ispra (VA) - Italy - TP 261
> Tel. +39 0332 78 3600
> margherita.di-leo at jrc.ec.europa.eu
> Disclaimer: The views expressed are purely those of the writer and may not
> in any circumstance be regarded as stating an official position of the
> European Commission.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
