[GRASS-dev] i.segment: invalid region id 0
Nikos Alexandris
nik at nikosalexandris.net
Tue Jul 16 04:18:33 PDT 2013
[previous discussion(s) erased]
A series of tests completed successfully for thresholds 0.1, 0.3, 0.5, 0.7,
0.9, no matter if memory= 300 or 30000. For the extreme case threshold=0.99,
the process failed for both memory= 300 or 30000 settings.
Note, all tests reported below were performed in a data base stored in an
external USB 3.0 HDD.
# grass version
g.version -g
version=7.0.svn
date=2013
revision=57074
build_date=2013-06-12
First the two failure cases:
# threshold 0.99, memory=300 (default setting)
time i.segment group=pan out=pan_segmented_threshold_0.99_memory_300
threshold=0.99
Loading input band...
Pass 1:
Pass 2:
Pass 3:
Pass 4:
Pass 5:
Pass 6:
Pass 7:
Pass 8:
Pass 9:
Pass 10:
Pass 11:
Pass 12:
Pass 13:
ERROR: Invalid region id 0
and
# threshold 0.99, memory=30000 --- This is what I have previously reported
time i.segment group=pan out=pan_segmented_threshold_0.99_memory_30000
threshold=0.99 memory=30000
Pass 1:
Pass 2:
Pass 3:
Pass 4:
Pass 5:
Pass 6:
Pass 7:
Pass 8:
Pass 9:
Pass 10:
Pass 11:
Pass 12:
Pass 13:
real 37m24.352s
user 37m14.000s
sys 0m0.784s
# A series of tests using default RAM
# threshold 0.1
time i.segment group=pan out=pan_segmented_threshold_0.1_memory_300
threshold=0.1
Pass 1:
Pass 2:
Pass 3:
Pass 4:
Pass 5:
Pass 6:
Pass 7:
Pass 8:
Pass 9:
Pass 10:
Pass 11:
Segmentation converged after 11 iterations.
Writing out segment IDs
i.segment complete. Number of segments created: 25407
real 8m9.122s
user 8m5.582s
sys 0m0.296s
# threshold 0.3
time i.segment group=pan out=pan_segmented_threshold_0.3_memory_300
threshold=0.3
Pass 1:
Pass 2:
Pass 3:
Pass 4:
Pass 5:
Pass 6:
Pass 7:
Pass 8:
Pass 9:
Pass 10:
Pass 11:
i.segment complete. Number of segments created: 11684
real 12m20.273s
user 12m19.466s
sys 0m0.256s
# threshold 0.5
time i.segment group=pan out=pan_segmented_threshold_0.5_memory_300
threshold=0.5
Pass 1:
Pass 2:
Pass 3:
Pass 4:
Pass 5:
Pass 6:
Pass 7:
Pass 8:
Pass 9:
Pass 10:
Pass 11:
Pass 12:
Segmentation converged after 12 iterations.
i.segment complete. Number of segments created: 5495
real 17m35.330s
user 17m34.302s
sys 0m0.264s
# threshold 0.7
time i.segment group=pan out=pan_segmented_threshold_0.7_memory_300
threshold=0.7
Pass 1:
Pass 2:
Pass 3:
Pass 4:
Pass 5:
Pass 6:
Pass 7:
Pass 8:
Pass 9:
Pass 10:
Pass 11:
Pass 12:
i.segment complete. Number of segments created: 4911
real 18m15.143s
user 18m11.188s
sys 0m0.300s
# threshold 0.9
time i.segment group=pan out=pan_segmented_threshold_0.9_memory_300
threshold=0.9
Pass 1:
Pass 2:
Pass 3:
Pass 4:
Pass 5:
Pass 6:
Pass 7:
Pass 8:
Pass 9:
Pass 10:
Pass 11:
Pass 12:
Pass 13:
Segmentation converged after 13 iterations.
i.segment complete. Number of segments created: 1276
real 30m30.619s
user 30m29.010s
sys 0m0.272s
# Tests using max. RAM
# threshold 0.1
time i.segment group=pan out=pan_segmented_threshold_01 threshold=0.1
memory=30000
Pass 1:
Pass 2:
Pass 3:
Pass 4:
Pass 5:
Pass 6:
Pass 7:
Pass 8:
Pass 9:
Pass 10:
Pass 11:
real 8m5.619s
user 8m2.218s
sys 0m0.252s
# threshold 0.9
time i.segment group=pan out=pan_segmented_threshold_0.9_memory_30000
threshold=0.9 memory=30000
Pass 1:
Pass 2:
Pass 3:
Pass 4:
Pass 5:
Pass 6:
Pass 7:
Pass 8:
Pass 9:
Pass 10:
Pass 11:
Pass 12:
Pass 13:
Nikos
