[GRASS-dev] i.segment: invalid region id 0
Nikos Alexandris
nik at nikosalexandris.net
Tue Jul 16 04:21:49 PDT 2013
Moritz Lennert wrote:
> >> > time i.segment -w group=pan_r_ir out=seg_weighted_pan_r_ir
> >> threshold=0.01 memory=8192
> >> Loading input bands...
> >> Pass 1:
> >> ERROR: Invalid region id 0
> >> What could be the problem ?
Nikos Alexandris:
> > the same error today while performing a "random" test. Disk capacity and
> > RAM plenty here.
> > time i.segment group=pan out=pan_segmented_plantations_area_threshold_1
> > threshold=0.99
Markus Metz:
> In most cases, this threshold is too large. It should be between 0 and
> 1, and rather close to zero.
Testing up to the limits here... :-)
> > Pass 13:
> > real 40m44.339s
> > user 37m34.357s
> > sys 0m0.380s
> > Details
> > projection: 1 (UTM)
> > zone: 38
> > datum: wgs84
> > ellipsoid: wgs84
> > north: -2571782.5
> > south: -2574924.5
> > west: 359153.5
> > east: 359525
> > nsres: 0.5
> > ewres: 0.5
> > rows: 6284
> > cols: 743
> > cells: 4669012
This region is used for all test I am doing (posted earlier).
> > Let me know how I can help.
> Can you make the dataset available (off-list if need be)? I can not
> reproduce this error with the datasets I have.
I think not -- will ask though.
Nikos
