[GRASS-dev] [GRASS GIS] #2032: r.mapcalc does not always respect MASK
trac at osgeo.org
Tue Jul 16 11:26:55 PDT 2013
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: unspecified
Resolution: invalid | Keywords: r.mapcalc
Platform: Linux | Cpu: Unspecified
Comment(by glynn):
Replying to [comment:2 pvanbosgeo]:
> OK, thanks, I didn't know that / hadn't read that part of the manual
carefully enough. Perhaps not something that the user will encounter
often, but nonetheless, it is something I can see others might overlook as
well when using r.mapcalc. Perhaps a short note of this can be added to
the r.mapcalc help file (which is where I looked to see where my
expectations of the behavior of r.mapcalc were wrong)?
The behaviour isn't specific to r.mapcalc. Except for a few special cases,
the MASK behaviour isn't implemented by the individual modules, but by the
raster I/O library. You can observe the same behaviour with e.g.
r.neighbors.
The correct place to document this behaviour is wherever the MASK
behaviour is described, e.g. the rasterintro manual page and the r.mask
manual page. FWIW, the first sentence of the DESCRIPTION section of the
r.mask manual page (after the summary) is:
The MASK is only applied when reading an existing GRASS raster map,
for example when used in a module as an input map.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2032#comment:3>
