[GRASS-dev] [GRASS GIS] #2036: Failed watershed analysis on Grass
trac at osgeo.org
Thu Jul 18 04:54:08 PDT 2013
Reporter: mehmeto | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: 6.4.2
Keywords: grass, r.watershed | Platform: MSWindows 7
Cpu: x86-64 |
This is my first day with Grass GIS (version 6.4.2 for Windows). As I
tried
[http://grasswiki.osgeo.org/wiki/Quick_wxGUI_tutorial#Watersheds_and_streams
this tutorial] the watershed analysis failed.
I carefully put in the parameters as specified on the tutorial.
The error message is:[[BR]]
(Thu Jul 18 14:10:00 2013)
r.watershed elevation=elevation at PERMANENT basin=elev.basins
stream=elev.streams threshold=10000
SECTION 1a (of 5): Initiating Memory.
SECTION 1b (of 5): Determining Offmap Flow.
SECTION 2: A * Search.
SECTION 3: Accumulating Surface Flow with SFD.
ERROR: G_calloc: unable to allocate 4 * 60175190 bytes at main.c:91
Subprocess failed with exit code 1
category information for [elev.basins] in [user1] missing or invalid
category information for [elev.streams] in [user1] missing or invalid
I will be glad to receive some help with this as my aim is to do
hydrological analysis with Grass. Please consider in your reply that I am
a novice with this program and I am not a technical person.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2036>
