[GRASS-dev] [GRASS GIS] #2036: Failed watershed analysis on Grass
trac at osgeo.org
Thu Jul 18 11:58:31 PDT 2013
Reporter: mehmeto | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: 6.4.2
Keywords: LFS, r.watershed | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by mehmeto):
Replying to [comment:4 neteler]:
> If you calculate 4 * 60175190 bytes = 240700760 which is > 2^31.
> It seems that you have hit the 2GB barrier on 32bit which means that
> either Large File Support (LFS) is not enabled in your copy of winGRASS
or
> that r.watershed lacks LFS support on GRASS 6 which I don't believe.
> (maybe related to ticket #1903)
With all due respect I can not understand why this may be the problem. I
am working with a standard demo file (North Carolina) that comes with the
installation package, followed instructions on a tutorial for beginners
located in the Grass Wiki, the layer I work on looks like to be a rather
small one as suggested by the tutorial, I downloaded the latest version of
Grass today (v. 6.4.3RC4), it seems they enable LFS on all new
installations as default and I work with a 64-bit Windows machine. Would
it not be strange to suggest such a problematic task in a beginners'
tutorial?
I looked for a way to enable LFS if it was disabled but [[Large File
Support this wiki article]] sounds rather technical and I failed to find a
procedure elsewhere. Also tried to do the same on a different computer
(again Windows 7) and got the same error message.
-Mehmeto
Ticket URL: <http://trac.osgeo.org/grass/ticket/2036#comment:5>
