[GRASS-dev] [GRASS GIS] #2036: Failed watershed analysis on Grass
trac at osgeo.org
Thu Jul 18 16:59:54 PDT 2013
Reporter: mehmeto | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: 6.4.2
Resolution: fixed | Keywords: LFS, r.watershed
Platform: MSWindows 7 | Cpu: x86-64
Comment(by glynn):
Replying to [comment:7 hamish]:
> > ERROR: G_calloc: unable to allocate 4 * 60175190 bytes at main.c:91
> (devs: should we strip the wingrass binaries in the stable release
builds? or keep the line number code there for better debugging?)
Stripping just removes debug symbols; it won't affect the error message,
which relies upon the G_calloc() etc macros passing `__FILE__` and
`__LINE__` to the underlying function.
> > If you calculate 4 * 60175190 bytes = 240700760 which is > 2^31.
> missed a 0, actually it's 9 times smaller than 2^31. It only wants to
allocate 241mb RAM
That's the allocation that fails. But main() allocates 2 such arrays, and
before that it calls init_vars(), which allocates 2 or 3 CELL arrays and
between 1 and 4 DCELL arrays. So the actual requirements are N*241 MB
where N is between 6 and 13. The upper bound comes out at over 3 GB.
And that's only the allocations which use size_array().
Ticket URL: <http://trac.osgeo.org/grass/ticket/2036#comment:9>
