[GRASS-dev] [GRASS GIS] #2038: wingrass7: v.db.addcolumn fails in attribute table manager
GRASS GIS trac at osgeo.org
Sat Jul 20 02:27:22 PDT 2013
 Reporter:  hellik                       |       Owner:  grass-dev@…
     Type:  defect                       |      Status:  new
 Priority:  major                        |   Milestone:  7.0.0
Component:  wxGUI                        |     Version:  svn-trunk
 Keywords:  wingrass, vector, attribute  |    Platform:  MSWindows 7
      Cpu:  x86-64                       |
 tested with nc-sample dataset in
 System Info
 GRASS version: 7.0.svn
 GRASS SVN Revision: 57202
 Build Date: 2013-07-18
 GIS Library Revision: 56211 (2013-05-12)
 GDAL/OGR: 1.9.2
 PROJ.4: 4.8.0
 GEOS: 3.3.6dev
 SQLite: 3.7.10
 Python: 2.7.4
 wxPython: 2.8.12.1
 Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
 g.copy vect=firestations at PERMANENT,myfire
 Copy vector <firestations at PERMANENT> to current mapset as <myfire>
 open attribute table manager => Add cloumn: addc1, type integer
 error message pops up:
 Error in v.db.addcolumn: access denied
 trying the same from the v.db.addcolumn-wxgui
 v.db.addcolumn --verbose map=myfire at user1 columns=addc2 integer
 Adding column <addc2> to the table
 (Sat Jul 20 11:08:52 2013) Command finished (1 sec)
 and from the layer manager-console
 v.db.addcolumn --verbose map=myfire at user1 columns=addc3 integer
 Adding column <addc3> to the table
 (Sat Jul 20 11:10:55 2013) Command finished (0 sec)
 maybe some calling-pythonscript-within-pythonscript issue?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2038>
