[GRASS-dev] [GRASS GIS] #2033: Moving g.pnmcomp to lib/display to improve render performance of wxGUI
GRASS GIS trac at osgeo.org
Tue Jul 23 06:39:14 PDT 2013
 Reporter:  huhabla                           |       Owner:  grass-dev@…
     Type:  enhancement                       |      Status:  new
 Priority:  major                             |   Milestone:  7.0.0
Component:  wxGUI                             |     Version:  svn-trunk
 Keywords:  display, Python, multiprocessing  |    Platform:  All
      Cpu:  All                               |
Comment(by glynn):
 Replying to [comment:4 huhabla]:
 Your tests are comparing raw BMP with PNG (which uses zlib compression).
 If you aren't seeing a significant difference between those two, then the
 I/O overhead is negligible and performance is dictated by rendering speed.
 Regardless of whether I/O uses mmap() or write() and read(), disk transfer
 doesn't get involved unless memory pressure is so high that the data gets
 discarded from the cache before it is read. And if memory pressure is that
 high, disk transfer will get involved anyhow when the "memory" buffers are
 swapped out (and if memory pressure is high and you don't have swap, then
 you'll just get an out-of-memory failure).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2033#comment:5>
