[GRASS-dev] start grass with only initializing the environment
Rainer M Krug
Rainer at krugs.de
Wed Jul 24 02:31:41 PDT 2013
Markus Neteler <neteler at osgeo.org> writes:
> On Mon, Jul 15, 2013 at 5:44 PM, Rainer M Krug <Rainer at krugs.de> wrote:
>> I would therefore suggest an additional startup argument for grass,
>> which only sets the environmental variables, including library paths,
>> so that GRASS commands can be executed afterwards, and if the
>> LOCATION_NAME and MAPSET are not provided, they will be null and *have
>> to be set manualy afterwards*.
>> This could e.g. have the name "-noui" indicating that no ui will be
>> started.
> I wonder what the difference to starting GRASS 7 with -text is...
> Maybe that's already enough?
No - this doesn't work.
The idea is to use this from R to set the environmental parameter when
using spgrass6. If I call grass -text from R (all in the terminal), the
grass session opens and I am in grass, but I can not do anything from R,
which I want to do.
So it seems that the grass startup script recognises that it is not in a
shell, and then starts one? If this starting of the shell could be
suppressed, I would expect that starting grass with the -text option
should work. I would assume that this would be similar to setting
GRASS_BATCH_JOB, only that GRASS does not exit automatically.
Something like a GRASS_BATCH_MODE - or one could call it a GRASS_SERVER_MODE?
Cheers,
Rainer
> Markus
Rainer M. Krug
email: RMKrug<at>gmail<dot>com
