[GRASS-dev] [GRASS GIS] #1358: WinGRASS 6.4.1: SQLite driver errors: `Unable to open database'
trac at osgeo.org
Thu Jul 25 04:30:58 PDT 2013
Reporter: rvanderweide | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 6.4.4
Component: Database | Version: 6.4.1 RCs
Keywords: wingrass, SQLite driver | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by mmetz):
Replying to [comment:11 mlennert]:
> Replying to [comment:10 mmetz]:
> > Replying to [comment:9 hamish]:
> > > unless someone has a bright idea for a minimally invasive fix,
bumping it down the road a little ...
> > With GRASS default settings, i.e. the sqlite database in the default
folder, this does not happen. Changing priority to minor, but the ticket
could also be closed as invalid. Essentially, this is a sqlite bug with
sqlite calling fsync() on the directory of the sqlite database even if the
directory contains files not related to the sqlite database.
> With the latest wingrass7 (July 18), after installation and download of
the NC data set, I get the following error:
g.copy vect=roadsmajor at PERMANENT,roads2
DBMI-SQLite driver error:
Unable to open database:
C:\grassdata\North_Carolina\user1\sqlite\sqlite.db
unable to open database file
no database is open
The sqlite mapset has the default settings
DB_DRIVER: sqlite
DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
You must have changed DB_DATABASE to
DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
but I guess that path does not exist.
The sqlite driver should be intelligent enough to create a new database
including the path to the new database if need be.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1358#comment:12>
