[GRASS-dev] [GRASS GIS] #2041: wxgui: error attempting to display imported raster map that was imported as three bands
trac at osgeo.org
Thu Jul 25 05:20:04 PDT 2013
three bands
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: raster import display | Platform: Unspecified
Cpu: Unspecified |
When you use the File->Import raster data->Common formats import wizard
frontend to r.in.gdal to import a raster file that will be split into
.red, .green, .blue bands on import, and you have "Add imported layers to
layer tree" checked, then you get an error message since the GUI tries to
zoom to and display a map with a name without the band extensions.
To reproduce, use the wizard to import any jpg, png, tiff or other raster
format that gets split into the three color bands.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2041>
