[GRASS-dev] [GRASS GIS] #2045: r.to.vect: use less memory
trac at osgeo.org
Fri Jul 26 04:49:32 PDT 2013
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.to.vect memory | Platform: Unspecified
Cpu: Unspecified |
Trying to convert a raster file to vector areas on a machine with 10GB,
the process was killed after having used up all memory and swap.
The CELL raster in question is an output of i.segment, is quite large and
has many small segments, i.e. many different raster values:
Rows: 53216
Columns: 49184
Total Cells: 2617375744
Although many of these cells are null:
total null cells: 2061717280
non-null cells: 555658464
It would be nice if r.to.vect could handle such large files without using
up so much memory.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2045>
