[GRASS-dev] [GRASS GIS] #2046: radius limitation option on v.voroni
trac at osgeo.org
Fri Jul 26 05:57:04 PDT 2013
Reporter: dnewcomb | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.4
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
In the calculation of foraging areas for different bird species, the
foraging areas can change based on the location of adjacent nests. I
would like to run v.voroni to calculate polygons out to a maximum radius
as a command line option. The end result would be similar to running
v.voroni on a set of points , running v.buffer on each point individually
create a series of polygon layers of individual circles ( that may
overlap), then intersecting the geometry of each v.voroni polygon with
each buffer individually to generate a series of polygon layers that are
then merged to a single polygon layer.
The bird species that I have in mind has an 800 m maximum foraging range.
The preferred out put in this case would be the standard v.voroni polygons
in areas where nests are closer then 800m. In areas where there are no
other nests within 800m the polygon would be an 800m radius circle. The
maximum distance from the origin point of the v.voroni polygon to any edge
of the output polygon would be no greater than the distance given in the
command line option ( in this case 800m)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2046>
