[GRASS-dev] [GRASS GIS] #2045: r.to.vect: use less memory
trac at osgeo.org
Fri Jul 26 08:10:56 PDT 2013
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.to.vect memory | Platform: Unspecified
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:2 mlennert]:
> Replying to [comment:1 mmetz]:
> > Replying to [ticket:2045 mlennert]:
> > > Trying to convert a raster file to vector areas on a machine with
10GB, the process was killed after having used up all memory and swap.
> > There was a memory leak in r.to.vect, fixed in trunk r57281.
> (and r57281)
> Thanks ! I now get through the "Extracting areas..." part without the
process being killed. I still see continuous increase in memory usage,
though, up to 88,5% at the end of the extraction stage. Is this normal ?
> Now it's busy writing areas...
And memory usage continued to increase. The process was killed during the
"Registering primitives..." step.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2045#comment:3>
