[GRASS-dev] [GRASS GIS] #995: WxGUI startup screen fails if GISDBASE path contains non-latin characters
trac at osgeo.org
Fri Jul 26 08:40:13 PDT 2013
Reporter: marisn | Owner: martinl
Type: defect | Status: assigned
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-releasebranch64
Keywords: wingrass, i18n | Platform: MSWindows Vista
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:19 mlennert]:
> Any news on this issue, at least for GRASS 7 ?
I've just tested in WinXP and can reproduce the startup error when the
path to GISDBASE contains special characters (in this case latin1
accents).
If I follow Maris' comment:18 then the only solution would be to call
grass.py directly from a python script, and not from a .bat. Is that
correct ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:20>
