[GRASS-dev] Custom GRASS command line prompt
Hamish
hamish_b at yahoo.com
Sat Jul 27 19:50:10 PDT 2013
Nikos:
> I want to alter the default GRASS command line prompt. For my needs,
> I find it better to have the current Mapset shown along with the
> Location.
> As a first experiment, I edited the corresponding file in place:
> grass7_trunk/dist.x86_64-unknown-linux-gnu/grass70.tmp, line 1039:
> - f.write("PS1='GRASS %s (%s):\w > '\n" % (grass_version, location_name))
> + f.write("PS1='G %s (%s/%s):\w > '\n" % (grass_version, location_name, mapset))
> Now it appears like: "G 7.0.svn (utm_37s/post):~ >". My understanding is
> that I probably need to edit the file:
> Do you have customised prompts? Any ideas for a more productive
> command line?
I'd suggest to put the change in ~/.grass.bashrc instead.
fwiw here's what I have there wrt the prompt:
SHORT_VER=`echo "$GRASS_VERSION" | cut -f1,2 -d. | sed -e 's/\.//'`
export PS1='G$SHORT_VER:\W > '
export HISTSIZE=3000
.or.
export PS1='G$SHORT_VER:\w > '
export PROMPT_DIRTRIM=2
as full dir path gets much too long, especially on WinGrass where the
terminal width is a pain to resize.
For simplicity one of my favourites is still just:
export PS1='GRASS$SHORT_VER> '
If you do most of your work with a small set of locations, it might
also be an idea to figure something out with Xresources to color the
terminal background based on which one you're running in.
regards,
Hamish
