[GRASS-dev] [GRASS GIS] #1997: i.landsat.toar for grass-dev is missing the option for landsat8
Nikos Alexandris
nik at nikosalexandris.net
Mon Jul 29 06:22:22 PDT 2013
Niko,
would you mind checking it this ticket is still "open" for you?
Cheers,
Nikos
Reporter: vesnikos | Owner: grass-dev@… Type: defect
> | Status: new Priority: normal | Milestone: 7.0.0
> Component: Imagery | Version: svn-trunk Keywords:
> i.landsat.toar | Platform: All Cpu: Unspecified |
> Comment(by vesnikos):
> some minor bugs during my tests:
> 1) Cosmetic typo at the description of sensor parameter:
> It says "Required only if 'metfile' not given (recommended by sanity)"
> should be ""Required only if 'metfile' not given (recommended for
> sanity)
> 2) Band8 (panchomatic) has my nature 15m res. The algorithm uses the
> regions resolution , and you cannot do anything to override it.
> 3) timestamp in r.info reads none, the date of acquisition is in the
> metadata, so it should be properly implemented
> eg: r.timestamp map=LC81840322013143LGN03_B10.toarr.1 date="$(date
> -d'$DATE_ACQUIRED $SCENE_CENTER_TIME' -u +'%d %b %Y %H:%M:%S.%N %z')"
