[GRASS-dev] [GRASS GIS] #2039: Startup Error
GRASS GIS trac at osgeo.org
Mon Jul 29 11:56:34 PDT 2013
 Reporter:  akdeakin  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.4.4
Component:  Startup   |     Version:  6.4.3 RCs
 Keywords:  wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-64    |
Comment(by hellik):
 Replying to [comment:6 helena]:
 > Now Richard has found that GRASS 7 works perfectly on Windows 7 and 8
 until ArcGIS 10.1 is installed.  Then, when ArcGIS 10.1 is installed,
 GRASS 7  exits immediately upon starting.  Actually, if you pause this
 jing video at 6 seconds, it shows 'importError: cannot import name
 MAXREPEAT'
 confirmed.
 ArcGIS 10.0 used C:\'''Python26'''\ArcGIS10.0
 ArcGIS 10.1 uses C:\'''Python27'''\ArcGIS10.1
 WinGRASS (osgeo4w/standalone uses C:\OSGeo4W\apps\'''Python27''')
 so no python version interference with ArcGIS 10.0, but then with ArcGIS
 10.1. e.g. I'm unable here on my laptop to start WinGRASS7-standalone
 > it shows 'importError: cannot import name MAXREPEAT'
 that's a lib mixing between ArcGIS 10.1-Python27 and WinGRASS-Python27
 there is a discussion on the way to solve this.
 http://lists.osgeo.org/pipermail/grass-dev/2013-July/065197.html
 best regards
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/2039#comment:7>
