[GRASS-dev] [GRASS GIS] #2039: Startup Error
trac at osgeo.org
Mon Jul 29 12:10:57 PDT 2013
Reporter: akdeakin | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Startup | Version: 6.4.3 RCs
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by mlennert):
Replying to [comment:8 neteler]:
> Replying to [comment:6 helena]:
> > For the record, this is what my colleagues found (which indicates
python version conflict with ArcGIS, already discussed on the list): GRASS
7 needs Python 2.7. I have several Python 2.7 installed on my machine,
so we started looking at that.
> > Now Richard has found that GRASS 7 works perfectly on Windows 7 and 8
until ArcGIS 10.1 is installed. Then, when ArcGIS 10.1 is installed,
GRASS 7 exits immediately upon starting. Actually, if you pause this
jing video at 6 seconds, it shows 'importError: cannot import name
MAXREPEAT'
> Perhaps this helps (http://grasswiki.osgeo.org/wiki/WinGRASS_errors):
> Q: Error message "!ImportError: cannot import name MAXREPEAT"
> A: A system-wide Python installation (2.7.2, independent of GRASS) may
cause the trouble. Replacing this system-wide Python installation with
version 2.7.4, instead of 2.7.2, solved the problem.
Could someone check what exact version ArcGIS installs. I suspect < 2.7.4.
Unfortunately, the Python launcher discussed in the thread Helmut points
to in comment:7 seems to only take into account minor version numbers, but
not revision numbers, so there does not seem to be a way to distinguish
between two versions of 2.7 on the machine.
Is it possible to uninstall the python installed by ESRI ?
One option would probably be to delete the registry key entries of the
ESRI Python version, install a more recent Python (e.g. 2.7.5) and install
the Python launcher.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2039#comment:9>
