[GRASS-dev] [GRASS GIS] #1986: dependecy problems: libgrass_rli.so versus libgrass_rli.6.4.3svn.so()(64bit)
GRASS GIS trac at osgeo.org
Sun Jun 2 02:07:09 PDT 2013
 Reporter:  zirneklitis  |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Default      |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 I build rpm-s from grass 6.4.3svn r56545 for Fedora 18 using the same rpm
 division –  grass, gras-libs, grass-devel, grass-debuginfo, grass-src.
 Gras-libs provides all libraries as  “libgrass_*.6.4.3svn.so()(64bit)”.
 The main grass rpm is happy with that except for library
 “libgrass_rli.so()(64bit)”. (grass-libs provides
 libgrass_rli.6.4.3svn.so()(64bit)). By the way: both files are created by
 grass-libs.rpm. Why the GRASS is looking for the wrong library?
 The workaround is to include a dependency tag “Provides:
 libgrass_rli.so()(64bit)” in the spec file.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1986>
