[GRASS-dev] [GRASS GIS] #1987: wxGUI: traceback in map selection drop down
GRASS GIS trac at osgeo.org
Sun Jun 2 16:27:29 PDT 2013
 Reporter:  hamish     |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  trivial    |   Milestone:  6.4.3
Component:  wxGUI      |     Version:  svn-trunk
 Keywords:  list tree  |    Platform:  Linux
      Cpu:  x86-64     |
 here's a traceback from the map selection dropdown list. all 6.4.3svn --
 7.svn.
 start the wxGUI. Add a raster or vector map. At the d.rast/d.vect dialog
 click the arrow to get the list of map names to select from. On one of the
 {>,v} Mapset: lines, on the bar to the _right_ of the words click and drag
 the left mouse button a little and you trigger it. In 6.4.3svn clicking on
 the mapset text closes the selector prematurely, in trunk it doesn't, but
 you get the same traceback error.
   File "/usr/lib64/python2.6/dist-
 packages/wx-2.8-gtk2-unicode/wx/lib/mixins/treemixin.py",
 line 502, in OnBeginDrag
 if self.IsValidDragItem(self._dragItem):
 line 569, in IsValidDragItem
 return dragItem and dragItem != self.GetRootItem()
 packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 5051, in
 __ne__
 return _controls_.TreeItemId___ne__(*args, **kwargs)
 TypeError
 in method 'TreeItemId___ne__', expected argument 2 of type
 'wxTreeItemId const *'
 tested on debian/squeeze 64bit.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1987>
