[GRASS-dev] [GRASS GIS] #1961: wxNVIZ: error if no raster map selected
GRASS GIS trac at osgeo.org
Mon Jun 3 12:13:39 PDT 2013
 Reporter:  hamish  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  major   |   Milestone:  6.4.3
Component:  wxGUI   |     Version:  svn-develbranch6
 Keywords:  wxnviz  |    Platform:  All
      Cpu:  x86-64  |
Comment(by annakrat):
 Replying to [comment:15 hamish]:
 > Hi Anna,
 > the two fixes (r56560 and r56551) seem good, thanks.
 backported
 > I don't have much interest in displaying centroids, but for the
 > sake of testing them, with the vector area and a points map already
 > loaded, go back to the Map Layers tab and edit the d.vect preferences
 > for the area map to show centroids too:
 The error is fixed in r56578. However showing centroids is controlled on
 3d view vector page - check load points checkbox
 > some other observations & 2c feedback:
 > perhaps make the default line width 1; width=2 looks a bit
 > "nibbled" (see screenshot), even after raising the height
 > above surface by about $nsres distance.
 > perhaps make the default line color a little more muted (aqua?)
 > perhaps make the default raster fine/coarse resolution 20-30% finer
 > and/or perhaps set the default coarse mode back to wire-frame.
 Some of the default values can be set in 3d view settings.
 > dragging layers around in the Map layers tab while in 3D view mode
 > is a bit clunky. afterwards I got a weird mix in the vector roads
 > map of some lines as the default blue,size=2 and others the modified
 > aqua,size=1 I did before loading the raster layer. (see screenshot)
 > you'll also notice in the screenshot a red-trail in the top right.
 > that always follows my mouse around, it disappears as soon as I move the
 > view-puck. shrug. (open source radeon driver on debian/squeeze)
 > rotate 3D mode is highly sensitive to mouse movement. fly-through mode
 > next door is very very slow to react. the normal Pan button seems to
 > do nothing other than redraw the scene as-is. (maybe have it
 > "Look: [here]" ?) hmm, after that fly-through mode no longer works..
 these things are quite experimental but the pan button should work (not
 really panning but it changes focus)
 This ticket is fixed (in terms of the initial problem).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1961#comment:16>
