[GRASS-dev] [GRASS GIS] #1988: towgs84 datum transform options not maintained with shapefile export
Casey Vandenberg
casey.vandenberg at sjgeophysics.com
Mon Jun 3 16:43:17 PDT 2013
Thanks Hamish,
I assumed it needed to be looked at with GDAL/OGR first when exporting
to a shapefile, I just wasn't sure if this was also the case when using
g.proj -e.
> Reporter: voncasec | Owner: grass-dev@…
> Type: defect | Status: new
> Priority: normal | Milestone: 6.4.3
> Component: Projections/Datums | Version: unspecified
> Keywords: g.proj, v.out.ogr | Platform: Linux
> Cpu: x86-64 |
> Changes (by hamish):
> * component: Default => Projections/Datums
> Comment:
> Yes, it's a known issue, and it needs to be solved in GDAL/OGR first. If I
> recall correctly, WKT doesn't have a defined way to include datum
> transforms, ISTR some time ago (older than that ticket) Frank suggested it
> could be packed into something like a comment term, but then that would
> only be known to other osgeo-stack software which knew to look for it.
> Also, the proj4 epsg file includes explicit +towgs84 terms for some SRSs,
> but others not (several options for the user to choose from under the
> umbrella of the generalized code); the one referred to in the gdal ticket
> (epsg:4632) is one of the ones with explicit +towgs84 terms in the epsg
> def'n.
> Hamish
