[GRASS-dev] Unexpected "v.db.select separator=newline" output
Nikos Alexandris
nik at nikosalexandris.net
Tue Jun 4 15:11:42 PDT 2013
Martin Landa wrote:
> > Hi,
Nikos Alexandris:
> > > v.db.select mangrove_sites_coordinates_latest col=cat,wrspr
> > > separator=newline | head
> > > catnewlinewrspr
> > > 1newline161043
> > > 2newline161043
> > should be fixed in r56593. Martin
> Thank you for your time Martin,
> it works with
> g.version -r
> GRASS 7.0.svn (2013)
> libgis Revision: 56211
> libgis Date: 2013-05-12 14:07:51 +0300 (Sun, 12 May 2013)
Sorry, that should be
g.version -g | grep rev
revision=56593M
Nikos
