[GRASS-dev] [GRASS GIS] #1996: r.random.cells not working correctly when min distance is < 0.1
GRASS GIS trac at osgeo.org
Wed Jun 5 02:22:06 PDT 2013
 Reporter:  pvanbosgeo   |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Default      |     Version:  svn-trunk
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 I am running r.random.cells in location/mapset with latlon with a
 resolution of 0.008333. When using a minimum distance of e.g., 0.09
 degrees, random locations / cells are selected that are closer then that
 distance, including selection of neighboring cells.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1996>
