[GRASS-dev] [GRASS GIS] #1996: r.random.cells not working correctly when min distance is < 0.1
trac at osgeo.org
Wed Jun 5 04:08:50 PDT 2013
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.random.cells | Platform: Unspecified
Cpu: Unspecified |
Comment(by pvanbosgeo):
The region's resolution is 0.008333. Good point about different distances
latitudinal and longitudinal. In my specific case it doesn't really matter
though, I just want to avoid to select any two cells that are e.g., less
then 2 cells apart). A minimum distance of 0.09 should take care of that,
shouldn't it. However, the resulting layer does still contain plenty of
neighboring cells selected (see attached image).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1996#comment:3>
