[GRASS-dev] GRASS 6.4.3 release planning
Markus Neteler neteler at osgeo.org
Wed Jun 5 13:37:20 PDT 2013
On Wed, Jun 5, 2013 at 10:08 PM, Michael Barton <michael.barton at asu.edu> wrote:
> I just was able to test g.extension on GRASS 7 compiled yesterday. I tried it with r.fuzzy because (IIRC) Markus said it is not broken and should install.
> Unfortunately, it does not yet work. Here is the error. Note that the demolocation is NOT my default or explicitly specified install location ($GRASS_ADDON_BASE is /Users/cmbarton/Library/GRASS/7.0/Modules).
It seems that demolocation is not found? It is used in the virtual session
set up during the compilation process which fails below:
> g.extension extension=r.fuzzy operation=add
> Fetching <r.fuzzy> from GRASS-Addons SVN (be patient)...
> Compiling...
> main.c: In function 'main':
> ERROR: LOCATION </Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.3.0/demolocation> not available
Is it possible that the copying of demolocation to that target is not
happening on Mac? It is actually needed.
Markus
