[GRASS-dev] Unexpected "v.db.select separator=newline" output
Nikos Alexandris
nik at nikosalexandris.net
Wed Jun 5 14:48:45 PDT 2013
@Martin
so, recompiled everything, and revision 56597M works fine with "-v vs=" as
well. It is nice that any string (literally) can be used as a "vs=" (tested
various stuff). This vertical output seems good for alternative reporting
style. Yet, the "-v vs=comma" doesn't really make much sense, does it?
v.db.select -cv wrs2_tiles_of_interest_testing col=cat vs=comma | head
1167
1179
2782
2789
8240
@Moritz & all
I'd still prefer to have an (extra?) option to get what you demonstrated so a
"cats" output can be used without shell magic to feed other modules.
Kindest regards, N
