[GRASS-dev] [GRASS GIS] #1999: r.mask with NULL map doesn't work
GRASS GIS trac at osgeo.org
Wed Jun 5 16:32:44 PDT 2013
 Reporter:  ferrouswheel  |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  normal        |   Milestone:  6.4.3
Component:  Raster        |     Version:  svn-develbranch6
 Keywords:                |    Platform:  Linux
      Cpu:  Unspecified   |
 When presenting r.mask with map containing all NULL values, it accepts the
 map and sets it as a mask.
 However, despite setting it as a mask, it does nothing. Instead of
 preventing all data from being available to read, it allows all data to be
 read.
 This is counter-intuitive. r.mask should either complain when setting a
 mask of all NULL values, or it should make it impossible to access any
 data (because there are no non-NULL cells in the source map).
 While one might question the use of a mask of all NULL cells, this can
 easily occur when scripting GRASS commands.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1999>
