[GRASS-dev] [GRASS GIS] #943: wxpython gui hangs after switching to cairo display driver
trac at osgeo.org
Wed Jun 5 17:37:28 PDT 2013
Reporter: epatton | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: cairo, driver, gui, wxpython | Platform: Linux
Cpu: All |
Comment(by hamish):
re the X error,
http://www.gtkforums.com/viewtopic.php?f=3&t=55792
quote:
There could be several problems here first one is related to this I found
by doing a search http://developer.gnome.org/gtk-faq/stable/x505.html. So
if you use fork() and then use exit() you have effectively closed the
socket
to the X11 server.
Another problem could be that you have a X11 socket connection created in
the parent via GTK and then trying to reuse it in the child processes with
the data entering the socket in a bad order.
(another web search mentions that X is perhaps not thread-safe)
I'm testing with Python 2.6.6 btw.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/943#comment:15>
