[GRASS-dev] [GRASS-SVN] r56622 - grass/branches/develbranch_6/mswindows
Hamish
hamish_b at yahoo.com
Thu Jun 6 01:16:06 PDT 2013
> > Author: hamish
> > Date: 2013-06-05 19:09:55 -0700 (Wed, 05 Jun 2013)
> > New Revision: 56622
> > Modified: grass/branches/develbranch_6/mswindows/env.bat
> > Log:
> > default to explictly using GRASS's bundled python.exe
> > to avoid startup breakage
Markus N wrote:
> let's backport to relbranch64 immediately. Otherwise it is
> hard to test if if also works there. Please let us not delay
> things forever.
the change was checked in a couple hours before the nightly build
rolled around. The plan was to wait for that, try it, then
backport. Total turn around time <12 hours.
I don't believe in backporting something* to the stable branch
that I haven't already tried in situ. The closer to a deadline
the stricter I'd be about that. (* aka sign off on)
regards,
Hamish
