[GRASS-dev] [GRASS GIS] #1282: WinGrass using www.python.org-installation
trac at osgeo.org
Fri Jun 7 04:45:24 PDT 2013
Reporter: hellik | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.4
Component: Packaging | Version: svn-releasebranch64
Keywords: wingrass | Platform: MSWindows Vista
Cpu: Unspecified |
Changes (by hamish):
* milestone: 6.4.2 => 6.4.4
Comment:
> Change %GRASS_PYTHON% in GRASS's env.bat as needed?
change of GRASS_PYTHON from "python" to
"%GISBASE%/etc/extrabin/python.exe" now applied in relbr64 and devbr6 to
avoid the reported version mis-match startup problems with wxGUI and
Python 2.7.2.
The GRASS+Msys startup method for wingrass continues to have $GRASS_PYTHON
= "python" as per Init.sh, so dependent on the $PATH. We'll have to watch
what happens there.
It seems to work in devbr6 for .py scripts called from the GUI, hopefully
"GRASS_PYTHON" is always launched instead of "python" so it will avoid
another installed version somewhere in the %PATH%. There are a couple .py
scripts and addons-- I assume on Wingrass the shebang is always ignored?
How about when called from msys?
This recent change is in basic disagreement with the thesis of this
particular bug report, so... I guess we'll see how it goes.
Anyone running custom .py addon scripts on Windows + GRASS 6.x are asked
to check if they still work.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1282#comment:3>
