[GRASS-dev] [GRASS GIS] #2000: wxGUI: Add command layer becomes	unusable
    trac at osgeo.org
    Fri Jun  7 05:43:13 PDT 2013
 Reporter:  hamish         |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  major          |   Milestone:  6.4.3
Component:  wxGUI          |     Version:  svn-trunk
 Keywords:  command layer  |    Platform:  MSWindows XP
      Cpu:  x86-32         |
 the "Add command layer" option is mostly unusable on Wingrass since you
 can't see what you're typing, and becomes oddly placed to the right of the
 other layer's preferences button on all platforms after you add a regular
 map layer.
 see attached screenshots.
 also I notice if I add a "--ui" or "--help" term to the command layer they
 silently get stripped off instead of acting as expected; and if I add a
 non-image creating module command is used there (like r.mapcalc) it seems
 to be ignored, limiting the kind of imaginative light scripting you can do
 with it.
 finally, if you press the Del key while editing text in that line, it
 deletes they layer line and everything you just carefully typed in. :-(
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2000>
