[GRASS-dev] GRASS 7 crashes on startup on Mac
Michael Barton
Michael.Barton at asu.edu
Fri Jun 7 08:28:24 PDT 2013
Maybe it is PYTHONPATH
BUT...
Python and the GUI is compiling and working just fine otherwise. And Python runs with no problem in the terminal.
The bogus errors for compiling mapswipe, composer, etc first appeared with what I think was the introduction of a new window class for these modules. I have not seen the toolbox, but it may reuse the same code. If I knew what this new code is, I might be able to troubleshoot it. But I don't have time to try to reverse engineer it without guidance as to where to look. The error on importing wx is misleading as to what the real error is.
I can't say for sure that these are all related (and the error is indeed somewhat different for the toolbox compilation). But it seems a reasonable place to start.
If it IS a PYTHONPATH problem, then the code for building the toolbox is somehow ignoring PYTHONPATH because this is set properly otherwise.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jun 7, 2013, at 5:20 AM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>>
wrote:
On Thu, Jun 6, 2013 at 7:16 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
Anna,
This is from the log. It looks to me like a path problem during compilation
File "tools/build_modules_xml.py", line 85, in <module>
sys.exit(main())
File "tools/build_modules_xml.py", line 77, in main
header(fh)
File "tools/build_modules_xml.py", line 58, in header
import grass.script.core as grass
ImportError: No module named grass.script.core
make[1]: *** [/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.3.0/etc/gui/wxpython/xml/module_items.xml] Error 1
make: [default] Error 2 (ignored)
make xml/menudata.xml
make[1]: `xml/menudata.xml' is up to date.
make menustrings.py
The other bogus errors on "No module named wx" also seems like a path problem.
yes, problem might be in PYTHONPATH. Could you ask about this William? I have currently no time and I am probably not able to solve this.
Regards,
Anna
Michael
______________________________
C. Michael Barton
Tempe, AZ 85287-2402
USA
voice: 480-965-6262<tel:480-965-6262> (SHESC), 480-727-9746<tel:480-727-9746> (CSDC)
fax: 480-965-7671<tel:480-965-7671>(SHESC), 480-727-0709<tel:480-727-0709> (CSDC)
www: http://csdc.asu.edu<http://csdc.asu.edu/>, http://shesc.asu.edu<http://shesc.asu.edu/>
On Jun 6, 2013, at 2:39 AM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
Hi, Michael,
On Wed, Jun 5, 2013 at 11:45 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
OK. I did this remotely but hopefully it is what you need.
yes, perfect, thanks. Could you try the compilation again with the change William did recently (demolocation probem, [1])? It might be related because from the errors in the log it seems that the virtual grass session is not there. If the problem is still there, please send me updated compilation log.
Thanks,
Anna
[1] https://trac.osgeo.org/grass/changeset/56621
C. Michael Barton
fax: 480-965-7671<tel:480-965-7671> (SHESC), 480-727-0709<tel:480-727-0709> (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
On Jun 5, 2013, at 2:22 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>>
wrote:
On Wed, Jun 5, 2013 at 11:07 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
Are you looking for the entire output from make?
just the make you run from gui/wxpython
Michael
C. Michael Barton
On Jun 5, 2013, at 1:56 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>>
wrote:
On Wed, Jun 5, 2013 at 10:38 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
Is the makefile output saved somewhere? I'm not at my office computer, but can access it remotely.
redirecting to file like this:
make 1> log.txt 2>&1
While this workaround works for me, it doesn't help as much for all the people who use my binaries.
Michael
C. Michael Barton
On Jun 5, 2013, at 1:35 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>>
wrote:
On Wed, Jun 5, 2013 at 9:59 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
OK. We are getting somewhere.
If I cd to the ../gui/wxpython directory inside the GRASS-7.0.app and run python core/toolboxes.py > xml/menudata.xml, it appears to create the menudata.xml file
GRASS then launches fine. It continues to launch fine subsequently.
Hm, so the problem is probably in the Makefile. Could you send me the whole make output (after make distclean)? Unfortunately I have very limited understanding of makefile rules, I was glad I made it work on my computer. At least you can use grass7 with this workaround now.
Anna
Michael
C. Michael Barton
On Jun 5, 2013, at 12:01 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
On Wed, Jun 5, 2013 at 1:40 AM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
Anna,
Still crashes.
See below.
On Mon, May 13, 2013 at 11:51 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
Perhaps I discovered the problem. Both the distribution version (downloaded in the past hour) and (of course) the compiled version of menudata.xml are empty.
Yes, that's what I was thinking. Could you try to run this separately:
I assumed that you want me to run this from the GRASS terminal prompt???
yes. Have you run this from gui/wxpython directory? At least xml directory must be there.
bash: xml/menudata.xml: No such file or directory
It's strange that Massimo recently compiled grass7 (with wxpython 2.9, but it should not be related, no gui is actually involved in this problem) and he didn't complain about this (Massimo, is that right?).
Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130607/fcff46b6/attachment-0001.html>
