[GRASS-dev] GRASS 7 crashes on startup on Mac
Michael Barton
Michael.Barton at asu.edu
Sat Jun 8 16:18:38 PDT 2013
I've been staying with wxPython 2.8.x Perhaps some of the new code only works correctly in 2.9?
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jun 7, 2013, at 8:39 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> I just compiled trunk, no compile errors, and GUI runs fine.
> OSX 10.7 Lion, Xcode 4.6.2 command line tools, wxPython 2.9.4
> I'm a bit lost now - what is the status of this, what is the current problem?
> On Jun 7, 2013, at 10:28 AM, Michael Barton wrote:
>> Maybe it is PYTHONPATH
>> BUT...
>> Python and the GUI is compiling and working just fine otherwise. And Python runs with no problem in the terminal.
>> The bogus errors for compiling mapswipe, composer, etc first appeared with what I think was the introduction of a new window class for these modules. I have not seen the toolbox, but it may reuse the same code. If I knew what this new code is, I might be able to troubleshoot it. But I don't have time to try to reverse engineer it without guidance as to where to look. The error on importing wx is misleading as to what the real error is.
>> I can't say for sure that these are all related (and the error is indeed somewhat different for the toolbox compilation). But it seems a reasonable place to start.
>> If it IS a PYTHONPATH problem, then the code for building the toolbox is somehow ignoring PYTHONPATH because this is set properly otherwise.
>>> On Thu, Jun 6, 2013 at 7:16 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>> Anna,
>>> This is from the log. It looks to me like a path problem during compilation
>>> Traceback (most recent call last):
>>> File "tools/build_modules_xml.py", line 85, in <module>
>>> sys.exit(main())
>>> File "tools/build_modules_xml.py", line 77, in main
>>> header(fh)
>>> File "tools/build_modules_xml.py", line 58, in header
>>> import grass.script.core as grass
>>> ImportError: No module named grass.script.core
>>> make[1]: *** [/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.3.0/etc/gui/wxpython/xml/module_items.xml] Error 1
>>> make: [default] Error 2 (ignored)
>>> make xml/menudata.xml
>>> make[1]: `xml/menudata.xml' is up to date.
>>> make menustrings.py
>>> The other bogus errors on "No module named wx" also seems like a path problem.
>>> yes, problem might be in PYTHONPATH. Could you ask about this William? I have currently no time and I am probably not able to solve this.
>>> Regards,
>>> Anna
>>> On Jun 6, 2013, at 2:39 AM, Anna Petrášová <kratochanna at gmail.com> wrote:
>>>> Hi, Michael,
>>>> On Wed, Jun 5, 2013 at 11:45 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>> OK. I did this remotely but hopefully it is what you need.
>>>> yes, perfect, thanks. Could you try the compilation again with the change William did recently (demolocation probem, [1])? It might be related because from the errors in the log it seems that the virtual grass session is not there. If the problem is still there, please send me updated compilation log.
>>>> Thanks,
>>>> Anna
>>>> [1] https://trac.osgeo.org/grass/changeset/56621
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
> - the wisdom of Tarzan
