[GRASS-dev] compilation of grass on AIX 7.1
Markus Neteler
neteler at osgeo.org
Sun Jun 9 14:05:43 PDT 2013
[side note: this system is a 3k-cores machine to which I kindly got
access, that's why
I am interested to get GRASS 7 running there]
I am configuring on AIX 7.1 like this, using the "new" install-sh from
https://svn.met.no/viewvc/fimex/branches/version0_28_x/install-sh?view=co
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/opt/freeware/bin/../libexec/gcc/powerpc-ibm-aix7.1.0.0/4.6.1/lto-wrapper
Target: powerpc-ibm-aix7.1.0.0
Configured with: ../gcc-4.6.1/configure --with-as=/usr/bin/as
--with-ld=/usr/bin/ld --enable-languages=c,c++,fortran
--prefix=/opt/freeware --mandir=/opt/freeware/man
--infodir=/opt/freeware/info --enable-threads
--enable-version-specific-runtime-libs --disable-nls
--enable-decimal-float=dpd --host=powerpc-ibm-aix7.1.0.0
Thread model: aix
gcc version 4.6.1 (GCC)
# AIX 7.1 - grass7.svn:
PREFIX=$HOME/bin
CFLAGS="-lstdc++" ./configure \
--prefix=$PREFIX \
--disable-shared \
--enable-largefile \
--with-cxx \
--with-proj-includes=$PREFIX/include/ \
--with-proj-libs=$PREFIX/lib/ \
--with-proj-share=$PREFIX/share/proj/ \
--with-gdal=$PREFIX//bin/gdal-config \
--with-sqlite \
--with-sqlite-libs=$PREFIX/lib --with-sqlite-includes=$PREFIX/include \
--with-tiff=no \
--with-png=no \
--with-fftw=no \
--with-cairo=no \
--with-opengl=no \
--with-freetype=no
GRASS is now configured for: powerpc-ibm-aix7.1.0.0
Source directory: /gpfs/home/neteler/software/grass-7.0.svn
Build directory: /gpfs/home/neteler/software/grass-7.0.svn
Installation directory: ${prefix}/grass-7.0.svn
C compiler: gcc -lstdc++
C++ compiler: c++ -g -O2
Building shared libraries: no
The compilation starts ok, then a few problems happen:
Errors in:
/gpfs/home/neteler/software/grass-7.0.svn/lib/vector/diglib
/gpfs/home/neteler/software/grass-7.0.svn/lib/rst/interp_float
/gpfs/home/neteler/software/grass-7.0.svn/db/drivers/sqlite
/gpfs/home/neteler/software/grass-7.0.svn/db/drivers/ogr
/gpfs/home/neteler/software/grass-7.0.svn/display/d.grid
/gpfs/home/neteler/software/grass-7.0.svn/display/d.path
/gpfs/home/neteler/software/grass-7.0.svn/general/g.copy
/gpfs/home/neteler/software/grass-7.0.svn/general/g.findfile
/gpfs/home/neteler/software/grass-7.0.svn/general/manage/lister
/gpfs/home/neteler/software/grass-7.0.svn/raster/r.carve
/gpfs/home/neteler/software/grass-7.0.svn/vector/v.build
/gpfs/home/neteler/software/grass-7.0.svn/vector/v.buffer
/gpfs/home/neteler/software/grass-7.0.svn/misc/m.transform
/gpfs/home/neteler/software/grass-7.0.svn/imagery/i.cca
/gpfs/home/neteler/software/grass-7.0.svn/imagery/i.cluster
/gpfs/home/neteler/software/grass-7.0.svn/ps/ps.map
.. (all Python dependent modules fail due to outdated Python there)
This long list can be reduced to perhaps "only" four problems.
I wonder if "--disable-shared" matters below.
In detail:
-bash-3.2$ cd /gpfs/home/neteler/software/grass-7.0.svn/lib/vector/diglib
-bash-3.2$ gmake
if [ "" != "" -a -f "".html ] ; then gmake html ; fi
==============TEST=============
gmake test
gmake[1]: Entering directory
`/gpfs/home/neteler/software/grass-7.0.svn/lib/vector/diglib'
: && gcc -L/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib
-o OBJ.powerpc-ibm-aix7.1.0.0/test
gmake test
gmake[5]: Entering directory
gcc -lstdc++
-I/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/include
-D_FILE_OFFSET_BITS=64 -I/gpfs/home/neteler/bin/include
-DPACKAGE=\""grasslibs"\"
-o OBJ.powerpc-ibm-aix7.1.0.0/test.o -c test.c
-o OBJ.powerpc-ibm-aix7.1.0.0/test OBJ.powerpc-ibm-aix7.1.0.0/test.o
-lgrass_dig2.7.0.svn -lgrass_gis.7.0.svn -lgrass_datetime.7.0.svn
-lz -liconv -lm -lgrass_rtree.7.0.svn -lgrass_gis.7.0.svn
-lgrass_datetime.7.0.svn -lz -liconv -lm -lm -lm
-lgrass_gis.7.0.svn -lgrass_datetime.7.0.svn -lz -liconv -lm
-lgrass_rtree.7.0.svn -lgrass_gis.7.0.svn -lgrass_datetime.7.0.svn
-lz -liconv -lm -lm -lm -lm
cd OBJ.powerpc-ibm-aix7.1.0.0 &&
GISRC=/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/demolocation/.grassrc70
GISBASE=/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0
PATH="/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/bin:/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/bin:$PATH"
PYTHONPATH="/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/etc/python:/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/etc/python:$PYTHONPATH"
LIBPATH="/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/bin:/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib:/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib:-L/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib
-L/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/lib"
LC_ALL=C ./test
diff OBJ.powerpc-ibm-aix7.1.0.0/test.tmp test64.ok
diff: Missing newline at the end of file OBJ.powerpc-ibm-aix7.1.0.0/test.tmp.
diff: Missing newline at the end of file test64.ok.
1c1
< double ��������double |a2U��double �double double double
|a2U�?double ������� float �� �float ����float
��float float �float ���?float �� off_t
�off_t �2��off_t off_t �[off_t ��� long
�long �2��long long �[long ���
int �int �2��int int �[int
��� short �short ��short short 90short
� char �char �char char
{char double ��������double ��U2a| �double � double
double double ?�U2a| �double �������float � ��float
����float ��float float �float ?���float
��off_t � off_t ��2�off_t off_t [� off_t
���long � long ��2�long long [�
long ���int � int ��2�int int
[� int ���short �short ��short short
09short �char �char �char
char {char
> double ��������double |a2U��double �double double double |a2U�?double ������� float �� �float ����float ��float float �float ���?float �� off_t �����off_t �2������off_t off_t �[off_t ��� long �long �2��long long �[long ��� int �int �2��int int �[int ��� short �short ��short short 90short � char �char �char char {char double ��������double ��U2a| �double � double double double ?�U2a| �double �������float � ��float ����float ��float float �float ?���float ��off_t ����� off_t ������2�off_t off_t [� off_t ���long � long ��2�long long [� long ���int � int ��2�int int [� int ���short �short ��short short 09short �char �char �char char {char
gmake[5]: *** [test] Error 1
gmake[5]: Leaving directory
gmake[4]: *** [default] Error 2
gmake[4]: Leaving directory
-bash-3.2$ file /usr/bin/diff
/usr/bin/diff: executable (RISC System/6000) or object module
I added two "file" tests in the Makefile to see what's in:
file test64.ok
test64.ok: c program text with garbage
OBJ.powerpc-ibm-aix7.1.0.0/test.tmp: c program text with garbage
--> No idea here.
cd /gpfs/home/neteler/software/grass-7.0.svn/lib/rst/interp_float/
gmake
gcc -lstdc++
-o OBJ.powerpc-ibm-aix7.1.0.0/matrix.o -c matrix.c
gcc -lstdc++
-o OBJ.powerpc-ibm-aix7.1.0.0/interp2d.o -c interp2d.c
gcc -lstdc++
-o OBJ.powerpc-ibm-aix7.1.0.0/point2d.o -c point2d.c
point2d.c: In function 'IL_check_at_points_2d':
point2d.c:54:43: error: expected identifier or '(' before numeric constant
point2d.c:78:3: error: 'r' undeclared (first use in this function)
point2d.c:78:3: note: each undeclared identifier is reported only once
for each function it appears in
point2d.c:87:5: error: lvalue required as left operand of assignment
point2d.c:88:2: error: 'zz' undeclared (first use in this function)
point2d.c:89:2: error: 'err' undeclared (first use in this function)
point2d.c:90:2: error: 'xmm' undeclared (first use in this function)
point2d.c:91:2: error: 'ymm' undeclared (first use in this function)
point2d.c:145:5: error: lvalue required as left operand of assignment
gmake[5]: *** [OBJ.powerpc-ibm-aix7.1.0.0/point2d.o] Error 1
gmake[5]: *** Waiting for unfinished jobs....
`/gpfs/home/neteler/software/grass-7.0.svn/lib/rst/interp_float'
--> No idea here.
cd /gpfs/home/neteler/software/grass-7.0.svn/db/drivers/sqlite
-bash-3.2$ gmake
-L/gpfs/home/neteler/bin/lib -o
/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/driver/db/sqlite
OBJ.powerpc-ibm-aix7.1.0.0/fetch.o OBJ.powerpc-ibm-aix7.1.0.0/select.o
OBJ.powerpc-ibm-aix7.1.0.0/listdb.o
OBJ.powerpc-ibm-aix7.1.0.0/describe.o
OBJ.powerpc-ibm-aix7.1.0.0/execute.o OBJ.powerpc-ibm-aix7.1.0.0/main.o
OBJ.powerpc-ibm-aix7.1.0.0/index.o
OBJ.powerpc-ibm-aix7.1.0.0/listtab.o
OBJ.powerpc-ibm-aix7.1.0.0/cursor.o
OBJ.powerpc-ibm-aix7.1.0.0/create_table.o
OBJ.powerpc-ibm-aix7.1.0.0/db.o OBJ.powerpc-ibm-aix7.1.0.0/error.o
OBJ.powerpc-ibm-aix7.1.0.0/driver.o -lgrass_dbmidriver.7.0.svn
-lgrass_dbmibase.7.0.svn -lgrass_gis.7.0.svn -lgrass_datetime.7.0.svn
-lz -liconv -lm -lgrass_dbstubs.7.0.svn
-lz -liconv -lm -lgrass_gis.7.0.svn -lgrass_datetime.7.0.svn
-lz -liconv -lm -lgrass_dbmibase.7.0.svn -lgrass_gis.7.0.svn
-lgrass_datetime.7.0.svn -lz -liconv -lm -lgrass_gis.7.0.svn
-L/gpfs/home/neteler/bin/lib -lsqlite3 -lm
ld: 0711-317 ERROR: Undefined symbol: .pthread_mutex_unlock
ld: 0711-317 ERROR: Undefined symbol: .pthread_mutex_trylock
ld: 0711-317 ERROR: Undefined symbol: .pthread_mutex_lock
ld: 0711-317 ERROR: Undefined symbol: .pthread_mutex_init
ld: 0711-317 ERROR: Undefined symbol: .pthread_mutexattr_init
ld: 0711-317 ERROR: Undefined symbol: .pthread_mutexattr_settype
ld: 0711-317 ERROR: Undefined symbol: .pthread_mutexattr_destroy
ld: 0711-317 ERROR: Undefined symbol: .pthread_mutex_destroy
ld: 0711-345 Use the -bloadmap or -bnoquiet option to obtain more information.
collect2: ld returned 8 exit status
gmake: *** [/gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/driver/db/sqlite]
Error 1
--> I suspect that the way how SQLite was compiled, influences that:
ls /gpfs/home/neteler/bin/lib/
gdalplugins libgdal.a libgdal.la libproj.a libproj.la
libsqlite3.a libsqlite3.la pkgconfig
I used:
PREFIX=$HOME/bin
./configure \
--prefix=$PREFIX \
--disable-tcl
-bash-3.2$ cd /gpfs/home/neteler/software/grass-7.0.svn/db/drivers/ogr
-bash-3.2$ gmake
-o /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/driver/db/ogr
OBJ.powerpc-ibm-aix7.1.0.0/cursor.o OBJ.powerpc-ibm-aix7.1.0.0/db.o
OBJ.powerpc-ibm-aix7.1.0.0/error.o OBJ.powerpc-ibm-aix7.1.0.0/driver.o
-lgrass_dbmidriver.7.0.svn -lgrass_dbmibase.7.0.svn
-lgrass_dbstubs.7.0.svn -lgrass_dbmibase.7.0.svn -lgrass_gis.7.0.svn
-lz -liconv -lm -L/gpfs/home/neteler/bin/lib -lgdal -lm -lrt
-ldl -liconv -lm
ld: 0711-317 ERROR: Undefined symbol: vtable for __cxxabiv1::__class_type_info
__cxxabiv1::__si_class_type_info
__cxxabiv1::__vmi_class_type_info
ld: 0711-317 ERROR: Undefined symbol: __gxx_personality_v0
ld: 0711-317 ERROR: Undefined symbol: __cxa_pure_virtual
ld: 0711-317 ERROR: Undefined symbol: .operator delete(void*)
ld: 0711-317 ERROR: Undefined symbol: std::basic_string<char,
std::char_traits<char>, std::allocator<char>
>::_Rep::_S_empty_rep_storage
ld: 0711-317 ERROR: Undefined symbol: .std::basic_string<char,
>::_Rep::_M_destroy(std::allocator<char> const&)
--> I see that -lstdc++ is missing?!
-bash-3.2$ grep stdc include/Make/Platform.make
CFLAGS = -lstdc++
It also comes up here:
-bash-3.2$ cd /gpfs/home/neteler/software/grass-7.0.svn/display/d.grid
-bash-3.2$ gmake
-o /gpfs/home/neteler/software/grass-7.0.svn/dist.powerpc-ibm-aix7.1.0.0/bin/d.grid
OBJ.powerpc-ibm-aix7.1.0.0/plotborder.o
OBJ.powerpc-ibm-aix7.1.0.0/main.o OBJ.powerpc-ibm-aix7.1.0.0/plot.o
OBJ.powerpc-ibm-aix7.1.0.0/fiducial.o -lgrass_display.7.0.svn
-lgrass_htmldriver.7.0.svn -lgrass_driver.7.0.svn -lgrass_gis.7.0.svn
-lgrass_datetime.7.0.svn -lz -liconv -lm -liconv -lm
-lm -lgrass_pngdriver.7.0.svn -lgrass_driver.7.0.svn
-liconv -lm -lgrass_gis.7.0.svn -lgrass_datetime.7.0.svn -lz
-liconv -lm -lm -lgrass_psdriver.7.0.svn -lgrass_driver.7.0.svn
-liconv -lm -lm -lgrass_driver.7.0.svn -lgrass_gis.7.0.svn
-lgrass_raster.7.0.svn -lgrass_gis.7.0.svn -lgrass_datetime.7.0.svn
-lz -liconv -lm -lm -lgrass_gis.7.0.svn
-lgrass_gproj.7.0.svn -lgrass_gis.7.0.svn -lgrass_datetime.7.0.svn
-ldl -liconv -L/gpfs/home/neteler/bin/lib/ -lproj -lm
-lgrass_symb.7.0.svn -lgrass_gis.7.0.svn -lgrass_datetime.7.0.svn
ld: 0711-317 ERROR: Undefined symbol: typeinfo for std::exception
ld: 0711-317 ERROR: Undefined symbol: .std::exception::~exception()
--> I see that -lstdc++ is missing.
The same applies to
/gpfs/home/neteler/software/grass-7.0.svn/display/d.vect.chart
--> Likely a "trivial" thing to fix it by gettings CFLAGS passed here.
Dirty hack (apply after configuring):
diff -u include/Make/Platform.make.org include/Make/Platform.make
--- include/Make/Platform.make.org 2013-06-09 22:43:54.000000000 +0200
+++ include/Make/Platform.make 2013-06-09 22:44:10.000000000 +0200
@@ -86,7 +86,7 @@
MATHLIB = -lm
ICONVLIB = -liconv
- INTLLIB =
+ INTLLIB = -lstdc++
SOCKLIB =
--> suggestions welcome how to properly solve it.
-bash-3.2$ cd /gpfs/home/neteler/software/grass-7.0.svn/ps/ps.map
-bash-3.2$ gmake
gcc -lstdc++
-DPACKAGE=\""grassmods"\" -I/gpfs/home/neteler/bin/include/
-o OBJ.powerpc-ibm-aix7.1.0.0/vect.o -c vect.c
vect.c:16:15: error: conflicting types for 'nearest'
/usr/opt/freeware/bin/../lib/gcc/powerpc-ibm-aix7.1.0.0/4.6.1/include-fixed/math.h:1397:21:
note: previous declaration of 'nearest' was here
gmake: *** [OBJ.powerpc-ibm-aix7.1.0.0/vect.o] Error 1
As workaround, renaming of "nearest" would likely do it as in:
http://trac.osgeo.org/grass/changeset/55563/grass/trunk/lib/gis/plot.c
gmake[3]: Entering directory
`/gpfs/home/neteler/software/grass-7.0.svn/vector/v.vol.rst'
gcc -lstdc++
-o OBJ.powerpc-ibm-aix7.1.0.0/user3.o -c user3.c
user3.c: In function 'POINT':
user3.c:658:35: error: expected identifier or '(' before numeric constant
user3.c:673:3: error: 'zz' undeclared (first use in this function)
user3.c:673:3: note: each undeclared identifier is reported only once
user3.c:675:3: error: 'r' undeclared (first use in this function)
user3.c:676:3: error: 'etar' undeclared (first use in this function)
user3.c:679:9: error: lvalue required as left operand of assignment
user3.c:680:6: error: 'ww' undeclared (first use in this function)
user3.c:681:6: error: 'err' undeclared (first use in this function)
user3.c:683:6: error: 'xmm' undeclared (first use in this function)
user3.c:684:6: error: 'ymm' undeclared (first use in this function)
user3.c:685:6: error: 'zmm' undeclared (first use in this function)
user3.c:718:6: error: 'wmm' undeclared (first use in this function)
user3.c:741:5: error: lvalue required as left operand of assignment
gmake[3]: *** [OBJ.powerpc-ibm-aix7.1.0.0/user3.o] Error 1
gmake[3]: Leaving directory
--> same as in /gpfs/home/neteler/software/grass-7.0.svn/lib/rst/interp_float ?
Summary:
- in the end the libgis problems previously reported by Ivan are gone.
- with above -lstdc++ the errors are reduced to these:
Errors in:
/gpfs/home/neteler/software/grass-7.0.svn/raster/r.resamp.rst
/gpfs/home/neteler/software/grass-7.0.svn/raster/simwe/r.sim.water
/gpfs/home/neteler/software/grass-7.0.svn/raster/simwe/r.sim.sediment
/gpfs/home/neteler/software/grass-7.0.svn/vector/v.surf.rst
(Python related errors not listed).
Pretty good I would say.
Help welcome to get the compilation completed,
Markus
