[GRASS-dev] [GRASS GIS] #1633: Unable to display shapefile attribute table due to pipe characters in dbf field
GRASS GIS trac at osgeo.org
Sun Jun 9 22:48:15 PDT 2013
field
  Reporter:  richardc     |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  critical     |   Milestone:  6.4.3
 Component:  wxGUI        |     Version:  svn-releasebranch64
Resolution:               |    Keywords:  database, separator
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by hamish):
 maybe replicate what `find -print0` + `xargs -0` does and support fs=null
 for v.db.select?
 sample data:
 #easting,northing,text string
 599490,4920855,foo
 599590,4920755,bar
 599690,4920655,baz|qux
 599790,4920555,qux
 599890,4920455,foo
  v.in.ascii in=test_pipe.csv out=test_pipe fs=, x=1 y=2
 another less definitive but more probable to work with standard python
 string functions idea is to take advantage of the fact that v.db.select's
 fs= option can take an unlikely string, not just a single char:
  v.db.select test_pipe fs='{_sep_}'
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1633#comment:14>
