[GRASS-dev] [GRASS GIS] #2001: wxGUI: traceback when using alternate projection for map display coords
trac at osgeo.org
Fri Jun 14 01:43:58 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: svn-releasebranch64
Keywords: map display, coordinates | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:1 annakrat]:
> Try r56690-2 in all branches.
tested in 6.4svn, working well thanks.
two little things noticed:
- is it easy to change the mouse cursor to an hourglass then back to a
pointer while the epsg file is loading? or grey-out then re-activate the
+proj4 and epsg code text boxes while it is loading? (some sort of
feedback that something is happening since it takes ~5 seconds)
- I'm not sure how much use the drop down menu really is since it is so
long (maybe better a spinbox?) but right now for me it is unsorted (~
backwards read?), so not so very easy to pick the one you want even if you
know the number.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2001#comment:2>
