[GRASS-dev] [GRASS-SVN] r56717 - grass/trunk/demolocation/PERMANENT
Markus Neteler neteler at osgeo.org
Sat Jun 15 04:12:54 PDT 2013
On Sat, Jun 15, 2013 at 1:08 PM, Hamish <hamish_b at yahoo.com> wrote:
> in the case of the demolocation PROJ_INFO file I think it's
> enough to just craft it by hand to make it as it should be.
Well, then this should be followed by a test if "v.unpack"
works with it. All problems arose while trying to transfer
a country map (from NaturalEarth )into it which I prepared
time ago in a different latlong location.
Markus
