[GRASS-dev] [GRASS-SVN] r56717 - grass/trunk/demolocation/PERMANENT
Markus Neteler neteler at osgeo.org
Sat Jun 15 04:39:41 PDT 2013
On Sat, Jun 15, 2013 at 1:33 PM, Hamish <hamish_b at yahoo.com> wrote:
> The v.unpack projection matching method is fundamentally flawed
> and should not be trusted.
> line 102:# check projection compatibility in a rather crappy way"
> It is not impossible to write a good check, but as an
> understatement, it is rather complicated.
Perhaps it would be worthwhile to get the (good) checks done in
v.in.ogr into the Python API?
Markus
