[GRASS-dev] unit tests?
Eric Momsen eric.momsen at gmail.com
Sat Jun 15 07:32:55 PDT 2013
I ended up using local scripts for the class project.  I also have the
impression that the wiki for the Test_Suite was planning ideas.
-Eric
On Sat, Jun 15, 2013 at 3:43 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Oct 17, 2012 at 5:06 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
> > On 17/10/12 16:58, Eric Momsen wrote:
> >> Hi all,
> >> I'd like to do some further enhancements of i.segment (GSOC 2012
> >> project, will hopefully send an official announcement soon!), and have
> >> a chance to use it for a class homework project... if I include some
> >> unit tests of the results.  I've previously used junit/Netbeans.  For
> >> GRASS development, I've been using Geany, and just kept a text file
> >> with commands to run after making changes.
> >> Does anyone run unit tests on individual modules, or have any advice
> >> on an easy way to set something up?  I read a little bit about cunit,
> >> but it was already taking longer than junit/Netbeans.  I just need to
> >> decide if it will be easy enough to add some unit testing, or if I'd
> >> be better doing something else for class and using the time learned to
> >> do c unit testing on more development on i.segment :)
> > It's been an on and off effort in GRASS, but check here for more info:
> > http://grass.osgeo.org/wiki/Test_Suite
> While a testsuite is there for a series of commands (I am happy
> to contribute more, e.g. by using the examples from the manual
> pages), I fail to activate them:
> [neteler at oboe v.unpack]$ pwd
> /home/neteler/grass70/scripts/v.unpack
> [neteler at oboe v.unpack]$ ls -la test_suite/
> total 4
> -rwxr-xr-x. 1 neteler gis 2180 Nov 10  2012 test.v.unpack.sh*
> [neteler at oboe v.unpack]$ make tests
> make: *** No rule to make target `tests'.  Stop.
> make: *** No rule to make target `test'.  Stop.
> Am I right that a "test" target is still lacking and the hints on above
> Wiki page are rather ideas?
> It would be important to have a "make test" target in the Makefile
> system, perhaps by moving the private one of
> lib/vector/diglib/Makefile
> to the main Makefile system of GRASS 7?
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130615/8bb97820/attachment.html>
