[GRASS-dev] [GRASS GIS] #2007: v.to.db azimuth direction
GRASS GIS trac at osgeo.org
Sat Jun 15 16:24:30 PDT 2013
 Reporter:  davidinosauro  |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  trivial        |   Milestone:  6.4.4
Component:  Docs           |     Version:  unspecified
 Keywords:  v.to.db        |    Platform:  Unspecified
      Cpu:  Unspecified    |
Comment(by hamish):
 v.to.db is a bit backward in this respect, elsewhere in grass the
 convention is always cartesian (theta CCW from the +x axis) not nautical
 (degrees CW from north). Without saying that one way is more appropriate
 than the other, I believe that for consistency v.to.db should be changed
 in trunk to match the rest.
 I've been slowly adding options to modules to allow both, but default to
 cartesian:
       aspect_type   Direction map aspect type
                     options: cartesian,compass
                     default: cartesian
 where `cartesian = 90 - compass` and vice versa. you can do that in
 db.execute to add the alternate convention into a new column.
 and if v.to.db+azimuth doesn't already error-out in a lat/lon location, it
 should. (even if using geodesics, great circle azimuth has two diff't
 answers depending on which endpoint you use, and it transitions along the
 line)
 patches for docs always welcome,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2007#comment:2>
