[GRASS-dev] ogsf, nviz, m.nviz.image build errors -- ticket #1423 ?
Nikos Alexandris
nik at nikosalexandris.net
Sun Jun 16 10:21:12 PDT 2013
Hi!
In Ubuntu 13.04, as you probably know, ogsf, nviz and m.nviz.image
(still) wont compile. This all is related to ticket
<https://trac.osgeo.org/grass/ticket/1423> I guess.
GRASS GIS 7.0.svn 56732 compilation log
Started compilation: Sun Jun 16 19:13:04 EEST 2013
Errors in:
/geo/osgeo/src/grass_trunk/lib/ogsf
/geo/osgeo/src/grass_trunk/lib/nviz
/geo/osgeo/src/grass_trunk/misc/m.nviz.image
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order
they
appear in the error log. If you get an error building a library, you
will
also get errors from anything which uses the library.
Finished compilation: Sun Jun 16 19:31:30 EEST 2013
make: *** [default] Error 1
Nikos
