[GRASS-dev] ogsf, nviz, m.nviz.image build errors -- ticket #1423 ?
epi
massimodisasha at gmail.com
Sun Jun 16 12:35:49 PDT 2013
i'm on ubuntu 13.04 as well
grass_trunk configured with :
./configure --with-freetype-includes=/usr/include/freetype2 --with-blas --with-netcdf --with-geos --with-lapack --with-odbc --with-pthread --with-readline --with-sqlite --with-wxwidgets --with-postgres-includes=/usr/include/postgresql --with-postgres
wx is 2.8 :
wx-config --version-full
2.8.12.1
i do not have errors to build ogsf/nviz/m.nviz.image
the only error i got are in
wximgview/xganim
i guess because of wx-2.8
attached the log :
https://gist.github.com/5793126
Massimo.
Il giorno 16/giu/2013, alle ore 13:35, Nikos Alexandris <nik at nikosalexandris.net> ha scritto:
> On Sunday 16 of June 2013 20:21:12 Nikos Alexandris wrote:
>> Hi!
>> In Ubuntu 13.04, as you probably know, ogsf, nviz and m.nviz.image
>> (still) wont compile. This all is related to ticket
>> <https://trac.osgeo.org/grass/ticket/1423> I guess.
>> GRASS GIS 7.0.svn 56732 compilation log
>> Started compilation: Sun Jun 16 19:13:04 EEST 2013
>> Errors in:
>> /geo/osgeo/src/grass_trunk/lib/ogsf
>> /geo/osgeo/src/grass_trunk/lib/nviz
>> /geo/osgeo/src/grass_trunk/misc/m.nviz.image
>> In case of errors please change into the directory with error and
> run
>> 'make'.
>> If you get multiple errors, you need to deal with them in the order
>> they
>> appear in the error log. If you get an error building a library, you
>> will
>> also get errors from anything which uses the library.
>> Finished compilation: Sun Jun 16 19:31:30 EEST 2013
>> make: *** [default] Error 1
> Same (almost) for grass64:
> GRASS GIS compilation log
> Started compilation: Sun Jun 16 20:24:02 EEST 2013
> Errors in:
> /geo/osgeo/src/grass64_release/lib/ogsf
> /geo/osgeo/src/grass64_release/lib/nviz
> /geo/osgeo/src/grass64_release/misc/m.nviz.image
> /geo/osgeo/src/grass64_release/visualization/xganim
> /geo/osgeo/src/grass64_release/visualization/nviz
> In case of errors please change into the directory with error and run
> 'make'.
> they
> will
> Finished compilation: Sun Jun 16 20:32:53 EEST 2013
> Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
