[GRASS-dev] [GRASS GIS] #2011: WxGUI, menu does not work at all (languages using double-byte characters)
GRASS GIS trac at osgeo.org
Mon Jun 17 19:47:50 PDT 2013
 Reporter:  venkat                       |       Owner:  grass-dev@…
     Type:  defect                       |      Status:  new
 Priority:  blocker                      |   Milestone:  6.4.4
Component:  wxGUI                        |     Version:  6.4.3 RCs
 Keywords:  encoding, wingrass, osgeo4w  |    Platform:  MSWindows 7
      Cpu:  Unspecified                  |
Comment(by venkat):
 "import re" works in the python tab in the layer manager.
 In fact, the problem is not only for r.colors but for
 all the menu items from the "Raster" pulldown (r.distance,
 r.buffer etc.).
 Typing the command (r.colors, r,buffer etc.) brings up the
 command panel without the error I reported. Problem is when
 we select from the pulldown "Raster" menu.
 Venka
Ticket URL: <https://trac.osgeo.org/grass/ticket/2011#comment:4>
