[GRASS-dev] [GRASS GIS] #2012: d.vect wx module GUI forgets column names
GRASS GIS trac at osgeo.org
Mon Jun 17 23:34:31 PDT 2013
 Reporter:  hamish  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  normal  |   Milestone:  6.4.4
Component:  wxGUI   |     Version:  svn-trunk
 Keywords:  d.vect  |    Platform:  Linux
      Cpu:  x86-64  |
 Hi, I notice if I add a new vector layer and in the symbol tab of the
 d.vect pop up GUI I set the symbol size_col and rotation_col options to
 column names, it works ok, but then if I go back to the vector layer ->
 preferences and the symbol tab again the given column names are gone &
 forgotten.
 If I press apply or ok a second time the map re-renders and those settings
 are lost.
 happens in all branches, e.g. for any points map: cat, cat, and size=1.
 (trying that for a line map [m.cogo import example] without a db
 connection or cat number for the line ends up in a traceback error)
 I also notice an error in trunk that the drop down menu for the column
 names is empty, but I can manually type "cat" there and it works.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2012>
